Hi I finished overclocking my 4670k and after stress testing on manual mode it is stable @ 4.5ghz 1.275 volts, however when I switched the voltage to adaptive mode it does not seem to be adapting and remains constant whether im at idle or under load.
I have the same issue, board is ASUS Maximus VI HERO, cpu is 4770K
here is how to enable low power options on a MSI board. should be similar for ASUS but they may name things differently. make sure your on the latest official bios
Haswell Low Power Modes
    Make sure you are on the latest official Bios!
Cpu ratio mode- Dynamic
Enhanced Turbo- Enabled
CPU core voltage mode- Adaptive
CPU ring voltage mode- Adaptive
Intel C-state – Enabled
C1E Support- Enabled
Package C-state limit - Auto
for windows users also make sure you set your minimum processor state to 5%
Windows7
->Control Panel\All Control Panel Items\Power Options\Edit Plan Settings
-->Change Advanced Power settings
--->Processor Power Management
---->Minimmum Processor state
-on battery 5%
-plugged in 5%
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
I have done all of that with no success :/
does your psu support haswell c states?
Corsair 250d - - Delidded i7 4770k @ 4.4GHz (1.15v) - - Asus Maximus VI Impact - - Corsair h100i
Asus DirectCU II OC GTX780 - - NZXT x41 & G10 w/ Push/Pull Noctua IndustrialPPC's - - Corsair ax760i
16GB Corsair Vengeance 2133Mhz  - - Samsung 840 pro (boot) - - Samsung Evo (gaming) - - WD green HDD (data)
