3 hours ago, Skydiver said:
It really depends on what needs you have. For example what speed you need, how many ethernet ports and whether wifi is important to you or not :)
My main goal is to have a good connection to my gaming pc and one ethernet port only and i do online gaming a lot
well that means you can either use a dLAN® 1200+ or a dLAN® 650+ depending on the internet speeds you get from your provider :).
