Hey I have the enthoo luxe and just purchased the phanteks 2m LED strip but found the adhesive strip falls off. I bought the 3m double sided mounting tape but this doesn't adhere to the back of the strip. Any suggestions. I was thinking of gluing the tape to the LED and cutting the tape into smaller pieces so its not in one long piece. What do you think?
https://linustechtips.com/topic/610058-phanteks-led/
Welcome to the Forums!
The 3M mounting tape should work without any issues as long as you clean the back of the LED strip off very well, I usually recommend this stuff as it's resistant to heat also being an outdoor tape. As for shortening the length of the strip that's doable with a soldering iron and some lead wires.
https://www.amazon.com/dp/B0083K36KA/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687742&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00004Z4BV&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=PKC778MZG3PGMHCWN98C
https://linustechtips.com/topic/610058-phanteks-led/#findComment-7891910
Hi there thanks for the info. I was looking at shortening the tape into a few shorter bits  not the LED strip. I will give it a go and let you know.
https://linustechtips.com/topic/610058-phanteks-led/#findComment-7900894
