It's not the issue that I cannot check Desktop capture. It's checked alright and I cannot record my desktop. I press Alt-f9 and nothing happens. I even tried holding ALT-f9 and there is no use.
Is there any other way to resolve this besides reinstalling Shadowplay
Here is my capture settings:
https://linustechtips.com/topic/609729-nvidia-shadowplay-desktop-capture-problem/
How do you know it isn't recording?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
I am using manual recording and if you see that gray square with a dot in the settings picture were it has a diagram of the monitor.
It's supposed to show that square with the gray dot on the bottom right corner and I didn't see it.
I have to wonder why you even need to... it seems you have a way to capture your desktop anyway!
I don't want to use Camtasia or Mirilis because Shadowplay has recorded my desktop really well. These two recorders also cost extra money.
You can use OBS Studio, which is also free, and can use the hardware encoder.
I haven't ever used Shadowplay myself, is there a manual record button you could use?
looks like you don't have shadow play turned on, click the shadow play button in GFE and make sure its on. if its on there should be an icon overlay on your desktop to indicate recording on/off.
Be the broken or the breaker. Be the giver or the undertaker. Unlock and open the door. Be the healer or the faker.
