Hello LTT forum! I've a wireless IP Camera which I need a wireless solution for. The IP Camera should be sent wireless (500 meters) to a laptop. I do not have any internet connection but I've power.
I been thinking about these: https://www.amazon.com/Ubiquiti-Litebeam-M5-23-GHz-airMAX/dp/B014S1JJVM/ref=pd_sim_147_14?ie=UTF8&dpID=41bLuXmyTML&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=022TR05YY5J7KQ7QY61A
But they are way too expensive, can it be done very cheap? :)
Thank you
https://linustechtips.com/topic/609674-wireless-ip-camera/
Thank you
would help if I could dude, why do you need wireless? Maybe there is a different solution. I use this.
https://linustechtips.com/topic/609674-wireless-ip-camera/#findComment-7886707
We need some more info about the 500 meters,
are there walls/trees/mountains?
Where are there power outlets?
Do you own the area inbetween?
If the camera is in a line of sight then you're best(wireless) option is to use direction pt-p devices like you suggested, but for 500m you can go cheaper and even used as long as theres a line of sight.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/609674-wireless-ip-camera/#findComment-7886791
