I am trying to fix an older computer of mine. It was once serviced for restarting every so often, because of the motherboard being to fastened to the case.
Now I am experiencing other troubles with it, and would love to get some help from you in figuring out what that problem is.
Every time I turn it on it restarts 5-10 seconds after. It doesn't even connect to the screen.
What do you guys think might be causing this?
Thanks in advance!
https://linustechtips.com/topic/608994-pc-wont-boot-need-help-troubleshooting/
3 minutes ago, VAkena said:
Make sure your video card is plugged in securely and remove components of the system that aren't necessary to try and pinpoint the issue
57 minutes ago, gFrenken97 said:
take out everything that is not neccessary to make it post
Ok i dc'ed the GPU and the system booted. I reconnect it. It boots. I remount the motherboard to the cache and close the cache. It won't boot. What next? :o
