HTML/CSS help ! (and other codes for web..)
so I want to create my own 404 page, so that whenever somebody types in the wrong sub-adress to my main domain, it not only showes them a web page regardless, but also a bit of text in witch it sais : page (insert whatever the guy typed here) not found.
but I want it to detect what the person typed in their browser's search bar. so that its done by itself and I don't have to make an infinite ammount of pages.
is this possible ?
how can I make it so that it alwais gets to this page if some random sub-adress is typed ?
https://linustechtips.com/topic/608893-htmlcss-help-and-other-codes-for-web/
1 minute ago, thekeemo said:
is the GET tage what you are looking for?
I do not know about said tag >.>
so probably...  i ill google it up :) thanks !
http://php.net/manual/en/reserved.variables.get.php
If you're hosting on your own server, I don't think its possible as lighttpd and some other webserver software only allows plain .html (no php etc) files to be used for error pages.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
nah im using a hosting service (hostinger.co.uk) wich provides php support. so im fine for that.
25 minutes ago, thekeemo said:
thanks !
in the root of your sites directory create a file called .htaccess if it doesn't exist and add the line
<code>
ErrorDocument 404 http://your-domain.com/your-error-page
</code>
Then if a request comes in and the server cant find the resource, it will serve your error page.
<code>
</code>
thank you !
do I need support for some technologies ? (say php..) for this ?
1 hour ago, givingtnt said:
thank you !
Nope, not for htaccess. But for getting the page you will need PHP or some overly fancy javascript. Off the top of my head, on the error page have something like
<?php
echo $_SERVER['HTTP_REFERER'];
in the body of the page.
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
<?php
echo htmlentities(parse_url($_SERVER['HTTP_REFERER'], PHP_URL_HOST));
But not sure if the Sub domain also is in there
else
<?php
echo htmlentities($_SERVER['HTTP_REFERER']);
Htmlentites make's a decent defense against people that want to inject malicious code while accessing your website, by changing the header.
You could probably do more, but this is a start.
Quote or mention me if not feel ignored
<?php
so my page would be :
<html>
	<body>
	<p>
      error404whatever page :
      	<?php
	  not found
	</p>
    </body>
 </html>
and it should display the text, then whatever adress is typed, then not found ?
YOU DON'T NEED PHP!
I did something similar once, in JS. For the whole link, there is the constant 'location'. If you want it without the protocol (http, ftp, file etc.) and the domain (www.linustechtips.com for example), just the '/main/topic/...' part then you have 'location.pathname'. There are few more of those in JS, but that should be all you need.
Edit: 'location' returns 'location.href' by default, but it might be good to made it specific by adding the '.href' part.
hostinger allows for custom pages. if you login in and go thre "website" section there is an option called "error pages" this allows you to edit the pages as you see fit.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
