Hi all,
I'm planning to build my own NAS server and currently I'm stuck on which case to build it in. My restrictions are:
  • mini-ITX MoBo
  • 3x 3.5" HDD
  • 1x 2.5" SSD (a proper bay is not really needed, I can even tape it to the case if need be)
  • Sober look (it will be somewhere in the living room, so nothing flashy)
  • As small as possible
I've found this helpful article that I can use as a guideline: http://jarvis.pimpmyrig.com/ The author uses a Fractal Design Node 304, but I believe there are smaller options available.
Any help?
https://linustechtips.com/topic/608581-case-for-a-small-diy-nas/
