PS4 Controller not syncing?
By
berderder
in Console Gaming
in Console Gaming
Solved by TheBestUserName,
Do the two cables you've tried include the one that came with the system? I have multiple cables, but I've found that the original cable is by far more reliable.
Try charging it on something else... your computer, cell phone charger, etc. Let it sit plugged in for a good 15-20 minutes, then plug it back into the PS4 to see if it'll pair up.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
