Hi, so I was originally going to get the Fractal Node 304, but now I am having to use an atx motherboard so if anyone knows of anything similar but atx that would be great!
Needs to be:
  • Small (I know its going to be at least 12x10" because of the size of atx, but as small as it can be other than that)
  • A few 3.5" hard drive bays
  • ATX
I would also really like it to be a sort of cube shape with a horizontal motherboard tray, basically like a scaled up node 304.
However I will look at any suggestions! Thanks
https://linustechtips.com/topic/608282-horizontal-atx-cube-case/
http://www.caselabs-store.com/bullet-bh7-atx-case/
E-ATX, 6HDD/12SSD, ATX PSU, upto 240mm thin AIO, Overall Exterior (W x H x D) 340mm x 267mm x 330mm.
That is as small as you can get it, unless you go SFX PSU and just about no storage space.
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/608282-horizontal-atx-cube-case/#findComment-7873188
This case is for a server which is going to go in a cupboard (i know bad for airflow but yolo) so now I am leaning towards just getting a 4u rack case. Not rack mount it though, just having it sat on a shelf.
So this topic has slightly changed, but any rack case recommendations? I'm not aware of any good or bad rack case manufactures, so was looking at this: https://www.servercase.co.uk/shop/server-cases/rackmount/4u-chassis/4u-standard-chassis-6x-35-hdd-+-2x-525-bays-sc-43400/
I know its not pretty, but meets all of my specification
https://linustechtips.com/topic/608282-horizontal-atx-cube-case/#findComment-7873659
