You're not getting much with that budget. Voice server you could probably get a RPI3
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/608275-gameserver-machine/#findComment-7872813
2 hours ago, Afro_Lamb said:
I am looking to build a system dedicated to running dedicated game servers and voice servers but i dont know what parts to use
Must haves
 - 8GB Memory
 - SSD (don't really need masses of storage)
 - 500GBP Budget (no peripherals)
Depending on the game server you could get away with really cheap hardware. Source games require almost nothing to run, but other more intensive games may need more power.
Also your home internet connection may not be strong enough to host servers with a lot of people, I wouldn't recommend having over 10 people on a home internet connection, so renting a server may be a bit more costly, but you will have a better expeience in the games.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/608275-gameserver-machine/#findComment-7873248
