Help finding a keyboard
Solved by WhiteManito,
This seems kinda okay, according to ratings, but because wireless mechanical keyboards are relatively "new", I wouldn't really buy one. http://www.amazon.com/XArmor-U9W-Wireless-Mechanical-Keyboard/dp/B004S862FW If you buy it, make sure that you don't have anything that could interfere the signal.
Nonetheless, I really recommend you to wait. If you really need a wireless keyboard buy a cheap membrane one and wait some time until mechanical wireless kbds get better.
