currently have 4670k
r9 390
16 gig ram
ssd
etc etc etc
I wanted to get up to i7 - 6 cores
was thinking
i7 4930k - buy used £250 - £487 new
i7 5820k - buy used £250 - £330 new
i7 6800k - buy new £370
32 gig ram
use existing r9 390
but its the price of the mother boards for the above 3 cpus - im looking at £180 for the cheapest motherboard - ive never spent that amount of money on a mb in the past!
I really want a i7 6 core pc - whats the cheapest way to get there?
I have a 7950 that was replaced by the r9 390, so the 7950 would go back in the 4670k pc meaning (if I do go to the i7) id have 2 very capable gaming machines.
https://linustechtips.com/topic/607898-help-me-upgrade/
r9 390
16 gig ram
ssd
etc etc etc
was thinking
32 gig ram
use existing r9 390
Are you sure you need 6 cores? It's quite overkill unless you're video editing or something along those lines.
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869037
Why do you want the upgrade?  I want to make sure you have a legitimate reason so you're not just wasting your money :)  Especially since it sounds like you already have a very good system.
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869043
I render in 4k about 2 times per month in prem pro, to be honest my 4670k at 4.2 can handel this quite easily.
I just wanted to go to 6 cores, and I really want to get up into the i7 range, im open to sugestions, to get me up into the i7 but id like 6 cores, unless you guys convince me to stay 4 core but move to i7.
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869046
I should of said I also have a 2 core e8000 pc that I run a teamspeak and and rust server on, I wanted to move this to the 4670k pc and build myself the i7 I spoke about above, I do know 6 cores is not really needed, I guess I just want to get up to the i7 cpus - god this is so hard.
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869057
r9 390
16 gig ram
ssd
etc etc etc
was thinking
32 gig ram
use existing r9 390
get the 6800k if you have the cash and you know you'll have to get new RAM along with a new motherboard, right?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869088
yes I do, its the price of the motherboards that get me though, that's why I don't mind getting used 4930k / 5820k
money is not the issue, but that does not mean I will splash the cash where its not needed lol
if I go used, I can get i7 6 core, new mother board and 32 gig of ram for around £600 to £650, as I have monitors cases ssds already here waiting
I just want best bang for buck while moving up to the i7s, my 4670k still kicks ass
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869118
the 5820k is more than enough, get that instead then.
Old Rig
https://linustechtips.com/topic/607898-help-me-upgrade/#findComment-7869125
  • 3 months later...
