Ok so I recently followed someones advice to try out dxtory. I downloaded it then tried out JackFrag's tutorial on setting it up. I downloaded the matrox codec and followed THE EXACT SETTINGS that he said to follow. I tried recording in 1080p60 (in csgo and overwatch) and all I got was a 30 fps pin in csgo. I have my csgo settings turned all the way down with multicore rendering off. I updated to the new version and tried it out again, it didn't work. I record in 1080p60 on Mirillis Action and it works fine. When I tried on the new version on overwatch, it didn't pin to 30fps, but it did incur a MASSIVE frame drop with a little icon.
(!)GPU
That's basically what the icon was.
The specs of my pc are in my signature, but for anyone lazy enough not to look, here are the specs:
A10-6800K
Asus A78M-A
Team Zeus Blue 8GB (2 x 4gb dimms)
XFX Double Dissipation R9 390
PLEASE HALP!!
https://linustechtips.com/topic/607878-issue-with-dxtory/
Does DXtory support hardware encoding? If so, turn that on.
Otherwise, OBS Studio is your best bet.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868787
2 minutes ago, jkeasley said:
I have no clue, but there is an option to force cpu processing
Oh, also, are you recording to an SSD or HDD? You should use the fastest drive you've got, even if you end up moving the clips to store on your HDD later.
Honestly, 720p60fps is fine for Youtube or Twitch (though you're recording to your computer not streaming, of course)
Again, try OBS Studio because I know that supports hardware encoding (that is, GPU encoding), which should fix the issue (I believe your CPU is having trouble keeping up)
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868816
Yes, but how is it having trouble keeping up, if I can record csgo in 1080p60fps on mirillis action. I'm having an issue where the speeds of my ssd, are the same as my hdd...
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868823
With mirillis action, I use GPU assisted encoding. NOTE: I need multiple audio layers and therefore can't use obs
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868830
OBS Studio supports up to 4 different audio tracks
That could be the issue, that your drive is slow.
CSGO isn't as visually complex as other games, therefore requires less speed to record
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868849
I have tried recording from 720p30 to 1080p60. It sat at the same fps on csgo. This should not happen considering that I can record 1080p60 using mirillis action.
Also, please note:
I am not using OBS Studio. I don't like it and how difficult it is to set it up. Worst come to the worst, I don't use Dxtory and just go back to mirillis action
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868861
OK, just try it to see if you've got the same issue. If you do, well it's hardware related.
If not, its just DXtory
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7868886
I don't think I would because Action has AMDvce and so does obs now...it's just a real pain to set it up, especially when you go from the regular mode to the advanced mode
https://linustechtips.com/topic/607878-issue-with-dxtory/#findComment-7869566
