So I just finished building my new machine. I'd love to work up the courage to install a custom loop but not there just yet...
I was going for a red theme initially, but now I kinda like this turquoise...
Intel Core i7 6700k - 4.6Ghz
Corsair H100i AIO
Asus Maximus VIII Hero Alpha
32gb G.Skill TridentZ - 3200Mhz
Geforce 1080 GTX FE
Soundblaster Z
3tb 7200rpm HDD
120gb Samsung 830 SSD (next on the upgrade list)
1200w Novatech Gold Modular PSU (overkill I know!)
Phanteks Enthoo Evolv Tempered Glass Case
https://linustechtips.com/topic/607376-project-el-psy-kongroo/
Great name ;) Are you contemplating an LED mod on the sound card?
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/607376-project-el-psy-kongroo/#findComment-7863603
Thanks :D Yeah it's pretty annoying if I want to change the colour :/ I might see if anyone else has done it (don't actually mind just disabling/covering it tbh)
https://linustechtips.com/topic/607376-project-el-psy-kongroo/#findComment-7863617
