HELLO EVERYONE ...yesterday it was running at 64c with ultra settings.....now what happn this i start the game and temps are growing up like a chicken is cooking so fast...i dnt even start the game i am just in play game screen the temps are going up 71C with medium setting...no overclocking...i've gtx 1080 Founders edition.!!!i am facing this problem now but not yesterday.!!
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/
The Fanboy Edition gets VERY hot - you can expect it to get to about 85*C and start throttling down
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862224
Not if he actually adjusts the fan curve and doesn't use stock settings...
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro - 4K 144HZ
PCPP: https://uk.pcpartpicker.com/list/mdRcqR
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862245
Then it runs loud AND hot.
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862247
Watch jayz2centz's video on it, it's' not as loud as you might think, definitely quieter than the older reference cooler design and temps drop by a good margin.
But yes I agree, should of waited for board partner custom cooled cards or water cooling.
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862254
Putting a crappy blower cooler on a 200W GPU is a bad idea (considering the autoOC function takes it to 1800 and beyond as seen above)
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862258
The AutoOC should not have been there, the card and cooler are ideally meant for stock speeds. Because that is pretty much what happens when it throttles, just goes back to stock lol
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862267
84*C at stock when it throttles and reaches equilibrium
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862274
49 minutes ago, razor007 said:
Damn bro...do u thnk my problem is relatd to next nvidia driver which is coming.??
Probbably drivers won't fix that.
Founders edition is kinda crapy. It won't cool your GPU as it should.
You need to create custom fan curve if you don't want high temps or to get bottleneck.
What about water cooling?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862647
I live in india bro..if i do water cooling then warranty problem!!!
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862683
Yeah that's true with warranty.
Should go with EVGA card because they allow you to change stock cooler with anything else you like, as long as you don't make any real damage to the card.
I guess you will just have to set custom fan curve. But as long as your card doesn't go over 80°C, you are jut fine.
Keep in mind that if card will be overheating, it will lower clock and start throttling, to prevent any real damage to card.
If there will be serious heat issue, card will also just shut down before any real damage take effect.
Don't worry too much ... those cards have some smart software looking out for health of it :)
WD My Cloud 4TB
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862714
True bro...evga was in my mind but as u know in india u cannot get things easily evga will come after msi,etc....no evga service center...nobody hv gtx1080 except only one shop....iam  really looking for the next driver!!
Refernce card gave me the hot chicken when i askd for the game no 8pin wires no gaming poster ahahah nothing just a box shit shit shit
https://linustechtips.com/topic/607215-gtx-1080-temps-problem/#findComment-7862803
