11 minutes ago, Jskn said:
FX6300 and GTX950
Don't use those PSUs. They are bad. I'd recommend anything from EVGA/Seasonic/XFX/Coolermaster (some of their PSUs)
https://linustechtips.com/topic/607107-surge-or-no/#findComment-7861078
I have to get a new monitor first, becuase I am using my kitchen tv, then I will probably get a modular PSU that's better
https://linustechtips.com/topic/607107-surge-or-no/#findComment-7861081
2 hours ago, Jskn said:
Does a CX430 have a built in surge protector, or should I shut he power supply off or unplug it?
The CX430 is 80+ certified, and therefore, has some powerline spike suppression. But, if you are really concerned about powerline spikes or surges - with any PSU - you should get a separate surge protector. (Usually built into a "power bar")
If you don't get a power bar surge protector, then it would be safest to turn off or unplug the PSU, but not very convenient.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/607107-surge-or-no/#findComment-7861574
