So I am trying to decide which is better to go with. FX 8320 (or 8350) or the Pentium G3258. I will actually save more by going with Intel but I am not sure if it will fit my needs. This will be for home use/light file server. I will use it to not only to store files but to use as my daily driver. I use word processing, youtube/web surfing, some very light gaming (nothing taxing even for a non gaming laptop),  and moving files between drives and two computers. When I use my pc (right now it is a Thinkpad T510) I always have lots of web browser tabs open, Word, Excel, and more open all at once.
My budget right now is $400 MAX!!! The AMD build will be more expensive than the Intel, but I already have an AMD MB. I have ram laying around as well. The Pentium build will cost me about $325 with tax, and the AMD will cost about $390 with a low end GPU. I could sell the AMD board afterwards to help make the Intel cheaper. Will the multi core AMD be better for my needs or the Intel? I can upgrade the Intel CPU after a year or two. I am staying with 1150 or AM2/3+ socket since I will be using Win 7 as my OS. I know AMD is not very strong in single core performance, but I would think with the work load I usually have, it shouldn't be too much for the FX CPU.
Any comments are welcome, just please leave the fanboy stuff at home.
I can send a link of the builds if yall would like.
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/606868-home-cpu-help/
