For some reason my PC refuses to let me set the intellimouse 3.0 to 500/1000hz even though I have used all the proper tools, following their directions exactly.
Also my local drive is D: not C:, even if I change the paths I can manually, would this cause an issue?
Specs:
Windows 7 Ultimate 64-bit
ASRock B75 Pro-3M
Intel Xeon E3-1231v3
https://linustechtips.com/topic/606720-help-overclocking-intellimouse-30/
Why create a new topic?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
Specs:
ASRock B75 Pro-3M
Uh.... how can the Xeon compatible with the Motherboard? that Xeon is LGA1150 and that motherboard is for LGA1155
23 hours ago, Meestagibbon said:
Their website must be wrong haha, under pcwizard it's listed as LGA1150
Its 1155....
10 minutes ago, Meestagibbon said:
Then we must have a problem boys because that is most definitely the mobo that I have..
It litterally cant be.
