that is the interconnect for your CPU to communicate with everything that is on the mainboard, it's located at the front side
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/605692-what-front-side-bus/#findComment-7846919
2 minutes ago, L0str31 said:
u mean this for cpu
yes the bus is formed on by the CPU side and the mainboard side, that spec pretty much states what speeds are supported on the mainboard side of the interconnect
https://linustechtips.com/topic/605692-what-front-side-bus/#findComment-7846943
