I've had a PC for awhile now and I wanted to upgrade to a new graphics card, but that required a new mobo. So I went to Amazon checked some out and found one that fit what I needed.
First off, I didn't know at the time that DDR3 and 4 had different slot but it's not a big deal.
The big deal is that it has the wrong cpu socket... For 6th gen cpus...
I have a 5th gen. And I don't believe I can send the mobo back.
What do?
https://linustechtips.com/topic/605308-motherboard-problems/
Try to send it back first.
Otherwise, you've got yourself a random MOBO. You'll need to buy a new CPU or another MOBO
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/605308-motherboard-problems/#findComment-7842777
