Hi guys.
I'm having a problem where my left shift will not work. I have tried updating my keyboard drivers. I've also tried turning on Mouse keys, Sticky keys, Toggle keys, Filter keys, underline keyboard shortcuts and access keys ond the last one Prevent windows from being automatically arranged when moved to the edge of the screen.
I tried a "loss" keyboard and there my left shift worked fine.
My computer is a laptop Acer.
My harddisk have been changed about 4 times in 2-3 years because I broke it... I don't know what kind of harddisk there are in my laptop now sorry...
My left shift have work before! It was fine yesterday but today it dosen't work at all!
If you need more information about my computer just message me and I'll try to answer as good as i can :)
Please help me! I need my left shift to work when I play games and all that... I hope you can help me make my left shift work again.
https://linustechtips.com/topic/605221-left-shift-not-working-laptop-help/
Have a look at this: http://www.keyboardtester.com/tester.html
or this: http://unixpapa.com/js/testkey.html
or this: http://www.asquare.net/javascript/tests/KeyCode.html
What model Acer laptop is it? Could be some kind of FN key screwing things up, it looks like this:
Note, Fn keys are not normally on the shift key but might as well check it and play around with it just in case.
I know you said you tried sticky keys but take a look at "All Control Panel Items\Ease of Access Center\Set up Sticky Keys" and make sure it is off. (That is for Win 8.1, you might find it for your OS somewhere else)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
moved to troubleshooting
Bittenfleax
I don't know what kind of Acer laptop it is sorry... I bought it for about 2-3 years ago and i got as a birthday present
Yes i do have a FN button and when i got my laptop i kinda "played" with it to see what it did...
I don't use windows 7 or 8 or 8.1
I use windows 10 but thanks for helping i will try it :)
I've tried the websites you sent to me and it shows that my left shift dosen't work at all :'(
Edited by Lunic1555
i forgot something XD
