So I'm using EKWB slim 240mm rad, together with some NZXT fans that I had for spare.
https://www.nzxt.com/products/fn-v2
Are those fans good enough for that rad?
When I put my hand on the rad, and I can't feel any air comming trought it. But when I put my hand on the side where fans are, I can feel it blowing in my hand.
I don't know how many ppi does this rad have, but I think it's pretty much, since air is acctually going the other way than it should be lol
Should I get some others fans maybe?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/605181-fans-for-radiator/
are you sure the fan is facing the right direction I don't mean to undermine you but that could ve the case but ive had good results with noctua fans in friend's builds so I recommend giving them a try
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
https://linustechtips.com/topic/605181-fans-for-radiator/#findComment-7841431
Fan is positioned right as it should be.
And if I remove fan from rad, it will blow in the right direction.
Seems like air is bumbing back or something like this.
Still temps on CPU are always below 50°C so it can't be that bad I guess xD
WD My Cloud 4TB
https://linustechtips.com/topic/605181-fans-for-radiator/#findComment-7841578
