So recently, the sensor of my g402 stops properly tracking. It happens when I'm playing CS (well it's the only time I would notice it anyway) and it just goes to like 10dpi which makes it impossible to aim. It started 3 days ago and it just randomly goes away after a few seconds. Any insights/ideas? (I'm using a steelseries qck+ large as the mouse pad)
edit, I apologies for the horrendous description.
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/604696-g402-sensor-problems/
Not too sure on this but three things I would reccomend if you haven't already done it:
-Turn off acceleration in the Logitech Gaming thing (like Razor Synapse)
-Put 'Raw Input' on in game settings
-Look at your DPI shifters and DPI settings
Sorry if this doesn't help :C
https://linustechtips.com/topic/604696-g402-sensor-problems/#findComment-7839959
everything is already set like this :/ seems like an actual sensor problem over software :(
https://linustechtips.com/topic/604696-g402-sensor-problems/#findComment-7840390
1 minute ago, Duck-dono said:
Ok... :C
Have you tried cleaning the glass protecting the sensor or the surface you use your mouse on?
Yah, it randomly happens :/
https://linustechtips.com/topic/604696-g402-sensor-problems/#findComment-7840412
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.
Hmmmmmm.
Do you have some sort of warranty for it or nar?
https://linustechtips.com/topic/604696-g402-sensor-problems/#findComment-7840422
Hmmmmmm.
Not sure, probably :P
https://linustechtips.com/topic/604696-g402-sensor-problems/#findComment-7840782
