Hi there
So, I have the following laptop Sony Vaio SVE1712W1EB.
- I added a 500gb 850 evo SSD.
- 16GB Ram
- Wifi AC Adapter
- New 1080p screen(Cause my cat jumped on top of it and the old one broke)
Now this laptop is extremely fast and I still like it but it seems to be overheating from time to time I assume it's both the CPU & GPU.
Even the VGA port is bend due to the heat I assume(I'll add a picture soon)
Now I'd like to reapply CPU & GPU thermal paste, but I'd like to know if this is a good idea in a laptop since I've never done this before.
I changed all the components myself and I've build my own PC.
Now I haave the following questions:
- Should I do it?
- If I do it which thermal paste should I use?
- Any tips when doing it?
- Any other feedback is welcome.
https://linustechtips.com/topic/604652-laptop-overheating-issue/
Try to clean fan and heatsink before you change thermalpaste.
If cleaning doesnt change anythink, then reapply a good thermal paste is a good idea.
For a thermalpaste, find a good thermal resistance and anti electric short for safety use.
Sorry for my bad english
https://linustechtips.com/topic/604652-laptop-overheating-issue/#findComment-7837976
Thanks, I've already cleaned out my entire laptop. And the thermal paste is the last resort :P
https://linustechtips.com/topic/604652-laptop-overheating-issue/#findComment-7841717
