Currently running a three year old Aspire V3 laptop and it's time to upgrade.
Looking to build a gaming pc for around $1400 CAD. The two components that I really want are a 1070 (have relatives in the states that will buy one if I send them money so I don't need to worry about the $300 markup) and from what I can see an i5 6600k will be good for my needs for quite a while.
I need help on the other components because I have no idea what's good in the low price range.
Would like to keep the cost under 1,400 but there is a little room to go higher.
Thanks for any help!
https://linustechtips.com/topic/604410-first-timer-build-need-advice/
http://pcpartpicker.com/p/BthrxY
you can replace the hard drive with a 250gb ish ssd and stay around your budget
this is in usd so it leaves $340 for the gpu
edit: can also go cheaper on the case if you want
Edited by Drunk_Klaus
This looks great! The 1070 won't be available for a little while I guess so I'll keep my eyes on prices.
Thanks a bunch man!
http://ca.pcpartpicker.com/p/FyYBD8 should do well does not have GPU pricing included.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Hey! I put aside $500 CAD for the 1070 and came up just over 1400. If it ends up converting to less money than that you're good.
OK, so I erased the build that was here because it's got a glaring weakness. A GTX 1070 is just way overkill for 1080p at 60Hz. So instead I'd suggest trying to get a 1440p monitor (they start at 380 CAD though) and perhaps a less powerful CPU.
This makes more sense.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($264.99 @ NCIX)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($59.99 @ NCIX)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  ($48.99 @ NCIX)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($62.99 @ NCIX)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($74.99 @ NCIX)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.98 @ NCIX)
Monitor: Acer G257HU smidpx 60Hz 25.0" Monitor  ($379.99 @ NCIX)
Other: GTX 1070 ($500.00)
Total: $1446.92
Generated by PCPartPicker 2016-06-01 00:33 EDT-0400
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
