Need help
Go to solution Solved by DioOmicida,
Geforce Experience serves a similar purpose. Gamefirst III is designed to work with the Asus products you probably own, though. If you don't like Gamefirst, you probably wont like any similar software.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/604111-need-help/#findComment-7829015
