My friend's computer has 100% disk usage, whenever he plays a game or opens a program, I used malware bytes , defragged the computer
its not a harddrive issue because i tried using another hard-drive and it was still at 100% disk usage
But in safe mode (networking) He is able to start and load up the games really quickly like there is no problems with the computer
https://linustechtips.com/topic/603934-100-disk-help/
HDD could be started showing it's age
Background programs that uses HDD heavily
What OS Pc running?
HP Probook 4540s
MoBo: HP 17F6 HM76 Panther Point
CPU: Intel Core i5 3210M 2.5Ghz
RAM: 8Gigs Hynix HMT DDR3-1600
GPU: AMD Radeon 7650M 2G (OC, from stock 500Mhz to 570-590Mhz)
Kingston SSDNow UV400 240gb
Standart 1366x768 16:9 Built in display
Mouse: Acme MA06 (it is cheap, but in games like GTA V Online, shooting is such good pleasure to own everybody!  )
And 40370mwh battery for outside fun
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827257
No background services running?
And Do you installed Windows on new HDD?
HP Probook 4540s
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827273
What Windows version you installed on it?
HP Probook 4540s
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827282
Can you give me full PC specs Please?
And on Windows 10 there's a an background service called: System and compressed memory  Which saves computer state before sleeping so that he could boot faster to that state after sleep, So if HDD is slower and older SATA( like 2) could lead to this problem. Try installing Windows 8.1
HP Probook 4540s
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827308
OHHH(Caps Lock :D ) those SATA cables!!!! What's was the problems with SATA cables?
HP Probook 4540s
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827330
The hard drive is showing its age, tell your friend to pick up a new hard drive. You can get a 500GB drive for about $60 and a 1TB one for about $100
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827340
Dude, HDD wasn't a problem. Read whole topic and then comment :D Those SATA cables :/ ......
HP Probook 4540s
https://linustechtips.com/topic/603934-100-disk-help/#findComment-7827355
