I posted recently asking a question about whether or not a graphics card upgrade would fix a driver issue and didn't really get any answers other than, essentially, "did you try fixing the drivers?" And yes, I did try that, but I'm upgrading either way. However, I have come up with a new question that I found interesting. I noticed that when I downloaded the most recent Nvidia drivers (for a 680), I noticed that when I went to custom install, it listed alle current versions of Nvidia software (ie Graphics driver, 3D vision, HD audio) as "none" except for the PhysX driver. Has anyone had this problem // does anyone know a solution?
https://linustechtips.com/topic/603720-geforce-driver-issues/
29 minutes ago, LabRat said:
if it's blacked out it might already be installed........... personally I never install all the bloatware. all I install is the graphics driver and the physx driver. you may want to look into that.
It's not that. My drivers are over a year old. It just says "None" under the Current Version section.
https://linustechtips.com/topic/603720-geforce-driver-issues/#findComment-7825505
