4 Pin PWM Fan Hub
iPC
Im looking for some 4 port, 4 pin PWM fan hubs for a 480mm and 560mm rad. Do you know of a fan hub that doesn't just distribute power? Thank you!
Swiftech or phyoba both make a really good power, PWM splitters:
http://www.performance-pcs.com/swiftech-8-way-pwm-splitter-box-sata.html
http://www.amazon.com/Phobya-4-Pin-Splitter-Power-Eight/dp/B00OD7MO6E
6 minutes ago, iPC said:
Not really related, but where can you buy the ASUS Fan Extension Card?
They don't sell them separately they only come with the X99 Deluxe board so the only option to get those really is through eBay.
31 minutes ago, W-L said:
I noticed that the fan splittersyou suggested only have 1 pwm slot. Are there any that have all pwm ports?
All the ports are PWM based ports only one port takes the RPM reading from a fan and has the other fans on the ports follow the first reading as long as all the fans are the same. Just note these will not work with 3 pin fans since they will just run at full speed and not allow for fan control.
36 minutes ago, W-L said:
Also, do you know of any SATA III to Molex adapters for a EVGA 1200 P2 PS to an EK XTOP Revo Dual D5 Pump?
Thank you. That clears it up!
If your just talking power adapters things like theses will work if you don't want to run an extra molex harness from the PSU:
http://www.amazon.com/StarTech-com-LP4SATAFM12-12-Inch-Molex-Adapter/dp/B00GK8SYCW/ref=sr_1_2?ie=UTF8&qid=1464555339&sr=8-2
9 minutes ago, iPC said:
Would that work for the instance mentioned above?
Yep that would work to convert sata power to molex for the pump.
Do you know of any >1000 W Fully modular Power Supplies that have molex connectors?
All of them should have some with them in the cable bag, even the EVGA P2 series, it's still a fairly used standard for LED's pumps, fan controllers and other accessories.
Is a Molex Cable a "4 Pin Peripheral Cable?'
Yes sometimes it is called that also.
