I just bought 2 Noctua NF-F12 for my Corsair H100I GTX and after install the fans, the pump on the cooler died (the pump sounds like its struggling to run and has become really loud and truns off before it even reaches the bios. I also cant hear any liquid moving around in the rad) I have the 3 pin power for the pump running straight from a molex adapter and the 2 fans were connected to the wires from the pump, not to the motherboard. I thought the fans would be fine to plug straight into the H100I but are they too much of a strain on the cooler?
https://linustechtips.com/topic/601962-help-h100i-shutting-down-computer/
When I had a H100I I put some Noctua fans on it and put them strait to the motherboard and I never experienced any issues whatsoever, so that's what I would recommend doing in your situation.
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
