Hi everyone,
I'd need a help to find replacement ear cushions for Steelseries 9H since the ones I have now got worn off and I might say accidently got rubbed by glasses(a lot of times xD).
So the cushions sizes are(if I measured them correct):
front side 100*90(height*width) mm outside diameter, 70*60(height*width) mm inside diameter,    ---> they look a bit oval ( https://goo.gl/KwP2Wt link to ear cushions )
back side 75*65(height*width) mm inside diameter(to place them on headset) and 30~mm height.
Any help finding replacement ones would be great since they are really nice pair of headphones, providing amazing sound but I'm out of warranty on them so...
Thanks in advance,B1GLeo
https://linustechtips.com/topic/601468-replacement-ear-cushions/
Look at ebay/amazon/craigslist
Ive recently purchase replacent pads for for my old Siberia V2.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/601468-replacement-ear-cushions/#findComment-7802143
The thing is there are no replacement pads for Steelseries 9H that are exactly the same unlike the case of siberia v2. I went trough alot of pages and still haven't found ones so I thought someone that is more in the audio stuff knows the right place to try find them.
https://linustechtips.com/topic/601468-replacement-ear-cushions/#findComment-7802150
19 minutes ago, B1GLeo said:
Hi everyone,
A pair of Brainwavz HM5 pads would probably fit fairly well on your headset. Give that a look. Here are their measurements for their non-angled pads.
Quote
https://linustechtips.com/topic/601468-replacement-ear-cushions/#findComment-7802151
4 minutes ago, B1GLeo said:
Oh yes, I already spoke with brainwavz support they are not 100% sure those would fit on the back side of headset although I think those would be something I'm considering to buy.
Just keep in mind that the pads will be able to stretch a bit so that you can get them to fit.
https://linustechtips.com/topic/601468-replacement-ear-cushions/#findComment-7802170
"Hi Leo ,
Thank you for contacting us.
If the Headphone Cup Measurements of the  Steelseries 9H match the dimensions of the Replacement earpads (within a margin of +/- 2 mm), then these would fit.
The Brainwavz Replacement Earpad's Dimensions are 110/90*75/65*28mm."
This is their response, so what do you think, would they fit? I'm not so sure what the 75/65 means(that might be the back side opening where the headset comes, if so then this is perfect match :)
https://linustechtips.com/topic/601468-replacement-ear-cushions/#findComment-7802251
