high memory, and odd drive question
Go to solution Solved by vixen609,
10 minutes ago, MichiganChucker said:
So, i got my ram, and motherboard back from rma's and everythings going decent till i started having brain farts here : / ..well, i noticed my mem was being used a lot. and wondered why that might be when im not really doing anything. i did start backing up my files but was happening before hand.
Also like Marcus said, it might just be how many apps running in the background, if so go to settings -> privacy -> background apps. and then disable some of the ones you don't use. Hope this helps! :)
https://linustechtips.com/topic/601404-high-memory-and-odd-drive-question/
it looks like you just have a crap ton of apps and stuff
Hmmm yeah i went thru and disabled a ton of stuff that M$ was eating up resources. like the stuff that sends random data, and disabled crap i dont use, im down now with World of warcraft running, this open, CL4, im at 4g so thats much better now.
