Help needed
Go to solution Solved by Guest,
33 minutes ago, HardlyDriven said:
Hey,
      I've been planning to build a PC and I've done some research but i need a final word. The following is the parts i have planned to use:
MoBo: Asus Z97-A
CPU: Intel i7 4790k running at 4GHz
GPU: MSI GeForce GTX 970
HDD: WD Blue 1TB
RAM: Corsair 16GB Vengence Pro (2x8GB)
Case: corsair Carbide SPEC-ALPHA
CPU Cooler: Hyper 212 Evo
I still need help on what SSD and what PSU i should by and what wattage it needs to be at.
I was hoping you can help me with this by telling me the parts i need or by improving the build. i want to use the PC for gaming (like GTA V and etc.)
My budget is around £1000. If you do improve it, i would like to keep the same case as it really like it.
Thank you,
Gavin.
You really should go with a 6700k over a 4790k
Hey,
MoBo: Asus Z97-A
HDD: WD Blue 1TB
Thank you,
Gavin.
https://linustechtips.com/topic/601267-help-needed/
11 minutes ago, HardlyDriven said:
Hey,
MoBo: Asus Z97-A
HDD: WD Blue 1TB
Thank you,
Gavin.
Go to PCpart picker and choose your parts then come back with the link!
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
https://linustechtips.com/topic/601267-help-needed/#findComment-7800126
Hey,
MoBo: Asus Z97-A
HDD: WD Blue 1TB
Thank you,
Gavin.
https://linustechtips.com/topic/601267-help-needed/#findComment-7800206
6 hours ago, HardlyDriven said:
So, would it work?  I've used some PSU calculators online and its telling me to get ~450w so i went with 500w
http://outervision.com/b/Vm5vZs
What is your max budget?
Ignore, read original post!
https://linustechtips.com/topic/601267-help-needed/#findComment-7804929
22 hours ago, HardlyDriven said:
http://uk.pcpartpicker.com/p/HcPFf8
Here you go but i had to chose a different case as the Corsair spec-Alpha wasn't on there so i picked one around the same price.
Better build! Recommend getting an SSD in the future when you can afford it!
http://uk.pcpartpicker.com/p/XTWrxY
https://linustechtips.com/topic/601267-help-needed/#findComment-7805101
