I had two 2 minute clips I put together in premier, but I can't seem to figure out the exporter. They are from a 1080p/30fps animation generated in another program, and I don't know what to do with all these export settings. I just need a single 4 minute 1080p/30fps clip on an AVI or something. If I could please get a basic walkthrough on what I need to do to export these clips. All my knowledge is derived from windows movie make, but it compresses like crazy.
I tried an export on my own, and found an area to custom set the resolution and frame rate. But it was saying it was going to take 2 hours to export, and I have a freakaing 5930K????? It looked like it was idling in task manager. Thanks in advance.
Main Rig "Rocinante" - Ryzen 9 5900X, EVGA FTW3 RTX 3080 Ultra Gaming, 32GB 3600MHz DDR4
https://linustechtips.com/topic/600766-help-exporting-in-premier/
1 minute ago, shermantanker said:
Do you need a plugin to do that? I don't really know much about video editing.
Nah, just click on your timeline, then click export. You should get the render window, just make sure the entirety of your project is selected to be rendered.
ASU
Post a screenshot of your settings when it said it would take 2 hours
But I don't see anything for H264
Here
I would try selecting a video codec.  If that doesn't work, I am not sure.  My computer at home does not have premiere on it so I am not able to try and mess around with the settings to try to solve.  If you still cant figure it out I can look into it in the morning when I have access to premeire.
