Hi LTT!
I've been google-ing my ass off for the pas couple hours but i couldn't find anything that would fix my problem. As the title says the wifi of my second laptop indicates that it's "Limited" while every other device in the house works perfectly. Does anyone have you an uncommon tip which would maybe fix the issue?
Things that I've tried:
- driver update
- turning the laptop wifi on and off
- turning the laptop on and off
- turning the router on and off
- entering this on CMD: netsh int ip reset
- Resetting TCP/IP in CMD // Auto-tuning:
netsh int tcp set heuristics disabled
netsh int tcp set global autotuninglevel=disabled
netsh int tcp set global rss=enabled
https://linustechtips.com/topic/600318-constant-limited-wifi-help-needed/
I'm guessing it's your windows network location that's the actual problem. Look here  https://tinkertry.com/how-to-change-windows-10-network-type-from-public-to-private
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Make sure the computer with the problem is set to obtain it's IP address via DHCP ("obtain automatically") and let us know what IP address it is getting from DHCP. If it can't get an IP address from the router, the computer will assign itself an IP starting with 169.254
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
