Today when i was going to school i found a IPhone 6(i think not sure is it is6 or 6s) and i turned it off so it doesn't ring in school, now im home and turned it on and it has no signal or anything, and it has a passcode and I'm trying to reach the owner but can't unlock it and can't do anything, any advice?
Thanks in advice
https://linustechtips.com/topic/600118-found-a-iphone-need-help/
Open up siri and say "call mom"/Call "dad"/Wife/husband  brother/sister etc.
see if they have a contact with mom in it.
(you don't need passcode to call and text with siri)
Could try an apple store, and they could look up the serial
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787379
It dosen't have signal,can't call anyone and cant acces the internet,since its locked the sim and mobile data so no acces to it
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787404
Does it show the carrier name on the top of the screen (next to the signal strength)? If so take it to that carrier and they can contact the owner.
if not, take it to the police or leave it on and hope they use FindMyiPhone to track it down, although I believe it needs data for it.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787430
What personal phone do you have? you may be able to insert the sim card in your phone and find the phone # and possibly contacts. Siri is a better option but it wont work with out service.
Its automatic, just press this button!
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787431
Take it, try and reset it, sell it..... im an evil person :(
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787442
I use a Samsung Galaxy Grand Neo,I will probobly try it
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787453
You won't be able to put the sim in, the iPhone uses nano sim, your phone will not take it. If you have a freind with a really new phone (nexus 6p/5x/galaxy s6/7/htc one m9/htc 10) you could ask them for help.
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787469
You can't as when you reset it using iTunes or any other method it requires you to enter in the Apple ID and the password... Twice.
Try to reset the iPhone, find the Apple ID, email to them about the iPhone.
Also if there's a "s" badge on the back of the phone it's a iPhone 6s
if it's huge it's a 6/6s plus
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/600118-found-a-iphone-need-help/#findComment-7787593
