Java Swing Icon Help
Solved by fizzlesticks,
public class B extends JFrame{
public B(){
Toolkit tk = Toolkit.getDefaultToolkit();
Image icon = tk.getImage(getClass().getResource("myicon.png"));
setIconImage(icon);
setSize(new Dimension(400,400));
setVisible(true);
public static void main(String...args) {
B b = new B();
Use a toolkit to load the image and get the path inside the jar file by using getResource(). This will look in the root of the jar. If you have a resources folder or something you can change it to getResource("somefolder/whatever/myicon.png");
