Monitor information I need
L0str31
I got one question about monitor I want buy monitor if I buy any monitor I mean brand newith 35 inch if I run to old desktop I will have problem or damage black screen Etc.
2 hours ago, DarkRuskov said:
i don't understand your question.
hahah i mean for example the motheroard have ram requirement for example ddr3 for ram ddr3 for monitor is this requirement exactly i mean if i buy i monitor brand new and i have old motherboard i run the monitor or not will have problem and black screen in monitor i don rly think u don understand because  u don did read be carefully
59 minutes ago, L0str31 said:
your english is just pretty bad, not your fault but don't put it on me. Then I guess you have a GPU with this board? otherwise any monitor should work, it's usually limited by software, but if you have a somewhat recent os it should be fine.
You'll need a GPU. The motherboard doesn't have on board graphics.
