XSPC Raystorm Pro
Go to solution Solved by Lurick,
Yah it will work just fine. All 115X sockets have the same mounting holes so if it works with one it will work with all of them even if not listed.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/599729-xspc-raystorm-pro/#findComment-7783425
