GPU/Display issue
Go to solution Solved by don_svetlio,
GPU is dead
Hello everyone, please excuse any mistakes, i'm new to the forums.
I'm looking for some help or clarification on this problem that i'm having.
Every so often, my screen will start to flicker and display random lines and colors. Is this a GPU issue or a display one?
I have 2 monitors connected up to my card, only one of the screens starts to flicker. The problematic display is using HDMI and the 2nd is using DVI to VGA.
Sorry for the bad picture quality.
Thanks in advance :)
https://linustechtips.com/topic/599668-gpudisplay-issue/
GPU is dead
https://linustechtips.com/topic/599668-gpudisplay-issue/#findComment-7782734
1 minute ago, ConeSC said:
Yay :)
Just what i wanted!
Try using DDU to reinstall the drivers or another cable on the off chance that the cause is not the GPU
https://linustechtips.com/topic/599668-gpudisplay-issue/#findComment-7782743
