So the bf of my sister gave me a vaio whitout a hard drive so i boot it up and it said missing os but i couldn't turn it off so i remove the battery and the power and when i tried to turn it on only the power button is on but theres no fan sound and it does not post or anything
i read that you have to do a overflow with a dyer or something but i dont wanna do that need help pls (pd:sorry for the bad english i don't speak very good english)
PDD:model: PCG-3J1L and VGN-FW550f
ask if someone need photos or video
https://linustechtips.com/topic/599339-help-whit-sony-vaio/
If you know what you are doing: remove normal battery and CMOS battery, wait, put everything back and try again.
Also trying to boot without normal battery is a possible solution.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/599339-help-whit-sony-vaio/#findComment-7779621
and how i remove the cmos battery if this pc is hard to open
https://linustechtips.com/topic/599339-help-whit-sony-vaio/#findComment-7779629
Some notebooks require a lot of dissasembly to reach it, it's possible you need to take it apart completely just to take out the battery.
Depends on how the notebook is constructed, but it being a vaio i can imagine it will require a complete disassembly.
https://linustechtips.com/topic/599339-help-whit-sony-vaio/#findComment-7779642
k
https://linustechtips.com/topic/599339-help-whit-sony-vaio/#findComment-7779650
