Requesting some help with buying an audio extension. I think what I have is standard which is 3.5mm jack. It's what fits in all my devices. (ex: front of corsair 300r and back of mobos)
I just want something that works doesn't go off, or become intermittent regardless of how I plug it in well. And of course the best value.
1m or 3 ft length is good for my use.
http://www.walmart.com/c/kp/audio-extension-cables
http://www.bestbuy.ca/en-CA/category/audio-cables/35933.aspx?type=product&page=1
http://www.monoprice.com/category?c_id=102&cp_id=10218&cs_id=1021808
https://www.amazon.ca/Cables-Go-40408-Extension-12-Feet/dp/B0012MMW7E
A while back, I bought a low quality audio extension (intermittent signal and breaking material) (this one I have, I have to rotate it because it won't work when it should in some ''positions'')
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/599251-audio-extension-cable/
1 minute ago, UnlimitedTMD said:
I suggest whatever length you need with real big sturdy plugs (Maybe even metal), and a thick cord.
DONT go cheap, they always break within weeks. Maybe even consider making your own (easy and fun)
Can you help me pick one out?
https://linustechtips.com/topic/599251-audio-extension-cable/#findComment-7778882
http://www.bestbuy.ca/en-CA/product/insignia-insignia-1-8m-6-ft-stereo-extension-audio-cable-ns-po35516-c-ns-po35516-c/10324434.aspx?path=de493777238ad7df11ea593fed10c6aaen02
looks decent, but I can`t seem to find good stuff on those sites, isn`t there like an american audio-website? Or a website that works (unlike monoprice). non-american here
to game or not to game, that`s the question
https://linustechtips.com/topic/599251-audio-extension-cable/#findComment-7778926
none of these are very high quality but the insignia looks ok
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/599251-audio-extension-cable/#findComment-7778932
