12 minutes ago, Mr.Reza said:
I want to buy a console sized (or a little bigger) case for GTX1080 and mini ITX mother board with 3 or 4 (maybe 2) space for  drives.
I don't want  any heat problems.
you could use the RVZ01, the node 202, Sugo SG13, stuff like this
https://linustechtips.com/topic/599202-help-for-buying-case/#findComment-7778284
Do you think  RVZ01 or node202 may have heat problem?
The RVZ01 has more internal bays for drives compared to the node202. The RVZ01 has 1 3.5" bay and 3 2.5" bays while the 202 has only 2 2.5" bays.
Heat shouldn't be a problem, things may get warm but unless you're doing super overclocking you shouldn't have to worry too much.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/599202-help-for-buying-case/#findComment-7778397
