i am planing my first computer build and i need to add a WiFi card to the build. i have to order it from www.amazon.co.uk as i live in Ireland. the mother board i am planning to use is
ASUS H110M-A . so if you could help me find a suitable card i would greatly appreciate it.
https://linustechtips.com/topic/599185-wifi-card/
Something like this:
https://www.amazon.co.uk/TP-LINK-TL-WDN4800-Wireless-Express-Adapter/dp/B007GMPZ0A
should work perfectly for your needs.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/599185-wifi-card/#findComment-7777983
