Need help with my mouse (CM Storm Mizar)
Zakcha
Probably a physical problem with censor or so, do you have the latest firmware installed?
MAIN RIG | AMD R7 1800x @ 4.0GHz [cooled by Corsair h110i] | Zotac 1070 founders | Corsair Dominator Platinum 2x8gb |
| ASUS crosshair IV hero | Samsung 960 evo m.2 | Seagate 1TB + WD blue 2TB| Corsair HX750i | Phanteks evlov atx TG |
LAPTOP | HP zbook Workstation | Intel i7-4710 HQ @ 2.5GHz | 8gb ram | NVIDIA Quadro k1100m | 250gb + 250gb Crucial SSDs |
I just tried without the mouse pad and it worked perfectly, but when on the mouse pad it dosen't :/ And yes i got the last firmware installed
Oh that's weird, but it leads to a simple conclusion, that specific sensor doesn't like that specific mouse pad. Nothing wrong with the mouse if it works fine on a different surface.
i tried with another mouse pad an it worked nicely, thanks for the help
Glad it worked out :)
