Ok, so I have a few problems with BF4. I have BF4 installed on 2 computers here, mine and my girlfriends. The problems happen to both of us but more so hers. We are still getting rubberbanding in BF4. Like we will be running and all of a sudden it like takes us back 5 to 20 steps. Very annoying. We get alot of packet loss out on alot of servers which seems to be causing the rubberbanding. Also we both can only join a few servers because Battlelog is not showing our ping on alot of them. If we try and join 1 that is not showing our ping it says the old " make sure port 3659 is open.. blah blah blah"  I have opened all ports for BF4 including that 1. I have repaired the game in Origin, reinstalled directx and punkbuster. Allowed Inbound Rules for Battlefield 4 and punkbuster A&B, through the firewall. Created and allowed a new Inbound rule for Battlefield 4 (protocol Type ICMPv4). Have tried running the game in 32bit instead of 64bit. Also tried running bf4.exe in high and low priority. Have tried it with overclocked and not overclocked CPU. We are using firefox for battlelog and I have disabled adblock. Have also tried it with the Bandwidth Optimization option on and off, made no difference. I feel like I have tried every trick in the book but I cant get it to run smooth. My computer seems ok but hers is rubberbanding alot more. Ok, some specs is what you guys need i guess.
Her computer:
CPU - A10-5800K 3.8GHz (4.2 GHz Turbo)
Cooler - Coolermaster D92
MoBo - Asus F2-A55-M
GPU - AMD HD 7950 Dual X 3GB
PSU - Antec VP450
RAM - 1x8GB Hyper X 1600MHz
SSD - 120GB Kingston V300
HDD - WD Red 1TB
OS - Windows 10 Pro
My computer:
CPU - AMD FX 8350 (overclocked to 4.8GHz)
Cooler - Corsair H100i
Mobo - Gigabyte 990FXA UD3 R5
GPU - MSI GTX 970 4GB Titanium Edition Armour2x
PSU - Corsair HX 1050
RAM - Corsair Vengence Pro 2x8GB 1600MHz
HDD - WD 1TB + WD 2TB
OS - Windows 10 Pro
Any help on this is appreciated. Thanks in advance.
https://linustechtips.com/topic/597974-bf4-problems-plz-help/
Rubber banding is pretty much guaranteed network. What is your point on the servers you do connect to?
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/597974-bf4-problems-plz-help/#findComment-7773236
