I need help. Me and my friends want to make a LAN party, but we also want to have an internet connection, most of my friends will be bringing laptops so they can access the main router which is on the first floor of the house using a wifi connection(This will allow them to be on the same local network as all the other ppl with laptops). But the problem is that some of my friends will be bringing desktops and we don't have cables long enough to go through the window. Is it possible to connect the desktops with a LAN cable to the wifi repeater? Will that allow them to connect to the same network as all the other ppl with laptops?
Thank you for your time.
https://linustechtips.com/topic/597543-lan-party-connection-problems/
What wifi repeater do you have?
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
lan party over wireless? glhf, but i would definitely recommend buying some cheap 8 port 1 Gbit (can even be 100 mbit) switch and a 25 meter cable :) (get them second hand for the best prices)
