I have a MSI 970 Gaming AM3+ motherboard, and today I noticed something on it. I am building a test bench in wood shop so I had to take it in for mounting hole placement measurements. I noticed there is a thingie (don't know the name, it is a silver rectangle with a amber-ish orange square in the middle) next to the top-right fan header (sorry I can't provide a picture. I will have one up as soon as I can.) In pictures I find it is perfectly vertical, but in mine the bottom part is towards the fan header. It looks bent out of place but I don't know how it happened or when it happened. Please help, don't want to kill a motherboard (and maybe a CPU+RAM)
Breaking things 1 day at a time
https://linustechtips.com/topic/597011-oh-crap-mobo-issue/
I don't see an "a silver rectangle with a amber-ish orange square in the middle" on that MOBO
https://us.msi.com/Motherboard/970-GAMING.html#hero-overview )
Could you at least circle it on an existing picture and upload that?
(With paint.net or something)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/597011-oh-crap-mobo-issue/#findComment-7754222
Its in yellow. When Im done at school I can get you a picture
https://linustechtips.com/topic/597011-oh-crap-mobo-issue/#findComment-7754262
3 hours ago, NextGenVII said:
Well my best bet is just to leave it if you do not want to stress it :D its fine man you wont kill it.
Ok. Good or bad idea to run it without my CPU? (The fans will starts and stuff just to see if It shorting anything)
@NextGenVII
@HPWebcamAble
https://linustechtips.com/topic/597011-oh-crap-mobo-issue/#findComment-7754354
That is definitely bent. I'm not sure if it will affect the MOBO's operation.
You might want to contact MSI and possibly RMA the board.
https://linustechtips.com/topic/597011-oh-crap-mobo-issue/#findComment-7755215
