Just want to get opinions on my planned build. I have all the time in the world before purchasing so suggestions are appreciated.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.89 @ OutletPC)
Motherboard: MSI B150M Night Elf (Buying locally)
CPU Cooler: Cooler Master Hyper 212X 82.9 CFM CPU Cooler  ($39.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($62.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.00 @ NCIX US)
Video Card: MSI Radeon R9 380 4GB Video Card  ($228.88 @ OutletPC)
Case: Fractal Design Arc Mini R2 MicroATX Mini Tower Case  ($69.99 @ NCIX US)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.99 @ SuperBiiz)
Total: $718.73
Generated by PCPartPicker 2016-05-16 00:16 EDT-0400
FYI. CPU Cooler just for silence, and because its within my budget.
I also wont need a HDD since I have a spare one from my old PC.
EDIT: FYI Again: List is for reference only. All parts will be bought locally.
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/596659-how-is-my-build/
1 minute ago, TrigrH said:
nice motherboard
Its not even listed in partspicker. But I can get one locally.
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750802
2 minutes ago, paprikman said:
Don't u have a seasonic s12g in local stores? It is not modular, but it's gold certified for almost the same price.
The rest seems fine to me :)
I'd have to check some website. But from the store I'm getting my parts, they don't have any. I don't mind the bronze certified M12II, it has positive reviews and that's all I need.
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750817
Looks solid if you're going to use new parts- nice deal on the SSD, good component selection. I don't know that the 212X is all that much quieter than the 212 EVO though- I'd just save $20 and go with the EVO. If that's too loud for you you can use the $20 to get a quieter fan.
Look at my systems:
My main testing/gaming system "Bitlo" is an upgraded HP Pavilion p6710f:
AMD Athlon II X4 640 undervolted to 1.225v vcore @3.00GHz, with additional undevolts for each P-state.
Stock AMD cooler- with the undervolt that's all I actually need
8GB PNY DDR3
Zotac GTX 560 Ti, 880MHz core & 2360MHz mem at stock voltage, has been delidded and repasted, plan on strapping an AIO on to overcome current temp issues
EVGA 500W PSU
120GB Toshiba Q300 SSD
1TB Seagate HDD
Every day carry: Toshiba Satellite L655-S5150. Pentium P6200 @2.13GHz, 4GB RAM.
Black themed workstation I'm working on:
Xeon E5-2670 (SR0KX)
Cooler Master Hyper T4
ASRock X79 Extreme4
16GB (2x8) Adata XPG DDR3
Gigabyte R9 290 OC Edition
Sound Blaster Audigy 2 ZS
Dell XPS 630i 750W PSU
OCZ Vertex 3 120GB SSD
Hitachi Ultrastar 1TB HDD
Diablotek EVO ATX Midtower case
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750837
All parts are new, except for the HDD. I don't really know the difference between 212x and the evo.
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750850
The Hyper 212 X is the newer version of the Hyper 212 EVO. It has a very slight performance improvement over the EVO, but ultimately is very similar. However, the EVO can be had for around $20-25 brand new, or even less used. There is very little difference between the fans on each as well. The 212 EVO is well known as being the price/performance king of air coolers.
Look at my systems:
8GB PNY DDR3
EVGA 500W PSU
1TB Seagate HDD
ASRock X79 Extreme4
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750866
I thought its just the same. I'd be choosing the 212 EVO. Thanks.
https://linustechtips.com/topic/596659-how-is-my-build/#findComment-7750964
